How to import my site into Frontpage
martin86
Master User
I have created a site using Easysite pro. There are very few options with Easysite. I am thinking of starting to use Frontpage, does this have more options and if I install it will i lose my current site?
2 REPLIES 2
Sogo7
Grand Master
To be painfully honest.. no
ESP and Frontpage are pretty much the same.  Probably the best thing you can do is use Wordpress, it's got plenty of add on modules so should do what you want.
Lovelogic.net UK Jobs Scanner
orthohin
Grand Master
