client account login
Dr_Dickie
Member
Hi using the the Easysite Pro to create a website. I would like to include a username and password login setion to direct clients to a secure folder with thier specific data on the website. Is this something that is possible and easily done. I would image I would need to have some kind of database set up on the website with clients allocated names and passwords on the website.
Any ideas
Many thanks
1 REPLY 1
agowans
Member
Hi Dr_Dickie,
If you have the Advanced Web Hosting package then you can password protect any folder on the site.  This would allow you to create a password protected section of your site.  You could then create a second website in ESWPro, publishing into a folder ie http://your-domain.co.uk/passwordprotected/ that you have set up password protection on.
Alternatively (with AWH) you could set up a series of password protected folders with UNs & PWs  each with their own content but this would require a lot of work.
Hope this helps.
