Broadband
Get support for BT Business Broadband and wi-fi products including hubs and BTnet.
Forum Posts
Frequently asked questions - Broadband
How do I do wiring checks? If you’re having trouble with your broadband, we recommend doing some simple wiring checks to find out what’s causing the issue. The checks differ slightly depending on what socket you have. Here’s a link to the guide for d...
BethM by Administrator
  • 3385 Views
  • 0 replies
  • 0 kudos
The new way to test your service
If you’d like to test your fibre broadband service without having to call us, we now have a new text service which can run tests without all the hassle - text Fault followed by your broadband telephone number to 60148. Your mobile will need to be reg...
  • 2890 Views
  • 0 replies
  • 2 kudos
Hybrid Connect
I believe this amy have been asked before but can anyone confirm or otherwise that port forwarding still works when the hybrid connect is live.We have a fixed/static external address and all works ok when fibre connection is live but port forwarding ...
Haggis by Member
  • 22 Views
  • 0 replies
  • 0 kudos
discs slower than before?
got some discs installed recently and was told by an engineer that our old repeaters are obsolete. Since the new ones, my download speeds have been way faster, but I seem to lag more in games. I'd rather have the slow download speeds than the lag. Do...
lorky by Member
  • 16 Views
  • 0 replies
  • 0 kudos
Bridge/Routed Mode: Block of 5 IP's possible?
Hello,I currently have a Hub2 in bridge/routed mode with a Meraki MX behind which is doing the PPPoE and firewalling. I have a single static IP.  I have enquired about adding a block of 5 IPs and was told this is available for an extra cost. Fine.I j...
DDIT by Member
  • 62 Views
  • 1 replies
  • 0 kudos
Openreach are a closed shop!
9 weeks in and over 2 weeks since opening our shop, Openreach are yet to install the cables to connect us. We are a small business and need internet to run our software. At the moment we have a Gigacube using 3G but it can't cope with the level of da...
@btconnect.com email address and residential FTTP broadband
I have currently a BT Business Broadband account*  with two @btconnect.com email addresses and a "digital landline" with a couple of Yealink phone handsets.As the business activity has ceased I want to change to a BT residential broadband package (FT...
rob-SMR by Member
  • 194 Views
  • 3 replies
  • 0 kudos
Why has my premium gone up but new customers pay £37 less?
I have 900Mb broadband no extras and this month it went up from £60 to £77, I was warned of this due to inflation.But looking at the sales page and none of the broadband packages went up with inflation for new customers, so 900Mb is £54.99 but curren...
goudd by Member
  • 185 Views
  • 1 replies
  • 1 kudos
Business Smart Hub 2 Port forwarding problem
I've accepted that there probably isn't a "solution" to this but are the Firmware developers even aware that it is an issue?Running a 3CX server behind a Smart hub 2 currently requires a DMZ configuration. Strictly speaking to pass the server's tests...
obroad by Member
  • 126 Views
  • 1 replies
  • 0 kudos
Windows 10 is ignoring the DHCP configured DNS server
This MIGHT be a Windows thing not a Smart Hub 2 thing but just in case...I'm using a local DNS proxy for ... reasons. I've configured the Smart Hub DHCP to supply the address of the proxy and for months it seemed to be working.Recently I've found tha...
obroad by Member
  • 206 Views
  • 3 replies
  • 0 kudos
