Member
0
BT WIFI HOTSPOT - no BT connect email address
Evening all. I have just cancelled my residential line and broadband as my work are providing it. They dont use the BTconnect email address. Can i still log in to the wifi hotspots and if so what details do I use. My work didnt seem to know.
Jo
Guru
0
Re: BT WIFI HOTSPOT - no BT connect email address
I assume you are being provided with a BT Business service.    If so there shoud still be an @btconnect.com user name asssociated with te account.   If you ahve that and the password - which is needed for the broadband login then you should be fine.   But remember,  you have to have your local BT WiFi hotspot enable to be eligible.
