Cyber Essentials questions - Business Hub 5
CyberStu1
Member
Hi There
I have Hub 5 for business and I'm trying to get Cyber Essentials certification for the business. I've got nearly all of it covered but the following two points are proving difficult to answer. Does anyone know if these two items are 'safe' by default?
1. Have all commonly attacked services (SMB, netBIOSm, tftp, RPC, rlogin, rsh, rexec) been disabled or blocked?
2. Confirm that any remote adminsitrative interface has been disabled on all firewall devices
Thanks in advance.
1 ACCEPTED SOLUTION
Accepted Solutions
markp
Grand Guru
Hi CyberStu1,
I can confim that the BT routers are PCI compliant, and that they cannot be accessed remotely.
Mark
View solution in original post
4 REPLIES 4
markp
Grand Guru
Hi CyberStu1,
Mark
CyberStu1
Member
Many thanks Mark.
Leonardo
Member
Hello MarkP,
What do you mean by being "PCI complaint" and "they can't be accessed remotely". I don't believe the latter is strictly true. Surely any router can be accessed remotely - under certain "specific" circumstances.
But, a supplementary question. I wish to have a static IP address, as My IP has been hacked and my Network and PCs are compromised. Whilst I am not a BT business customer, I actually have a small business and I am a BT domestic customer. Question: How can I upgrade or migrate to BT Business Broadband account, so I can get my IP changed?
Thank you. Regards, Leonardo
markp
Grand Guru
Hi  @Leonardo,
By access remotely I mean you cannot access them directly. You first need to access a computer behind the router at the location in question then use that computers local connection to the router to make any changes.
If you are wanting to move from home to business broadband so you can get a static IP, you need to contact business sales on 0800 800 152 they can organise the switch over for you.
Markp
