DHCP Table problems with BT hub 3
patbean
Member
We have bt infinity with a Hub 3 that we use in a pub/bar, any custpmers  cam use it. The DHCP table fills after a while and when it gets to about 150 new clients can't connect. A factory reset will fix the problem but it will come back often within weeks. Saving the configuration to a file doing a factory re-set and then restoring the backup dose not help as it also restores the DHCP Table! Can anyone help? as having to do this every couple of months is becoming anpying
0 REPLIES 0
