Member
0
Email servers unreachable from within BT
Hello,
I have an email address that uses these two email servers
pop.securemail.pro
authsmpt.securemail.pro
Since last Friday I'm unable to reach them when I'm hooked to the BT hub. But if I use my phone to tether to EE, everything works.
I have run a TRACERT on both and seen that, after a few hops, the trace stops and says the network is unreachable.
I have contated BT webchat support, but they don't understand what I'm talking about and they suggested me to call BT Tech Experts on the phone. Unfortunately, I'm a lodger and the account is not on my name, so, even though this has absolutely nothing to do with the home Hub, they simply can't help.
Any suggestions?
Thanks a lot,
Pierfranco
Moderator
0
Re: Email servers unreachable from within BT
Hi PierFranco
I've attempted to trace into the servers via a BT Connection and that works fine.
can you turn the connection off for 5/10 mins and then reconnect up, to ensure you get a new IP and see if that resolved the problem,
thanks
James
Member
0
Hi James,
thanks for checking. I'll have a go and let you know.
Cheers,
Pierfranco
Member
0
[ Edited ]
Still does not work. This is the latest tracert
Any ideas?
Thanks,
Pierfranco
Moderator
0
for some reason i cannot see the Image,
can you either PM me the picture or just copy and paste the data
James
Member
0
HI James,
I don't understand why it does not show my png. I'll try to post a link from gdrive
https://drive.google.com/file/d/11ebeW6YM9YI9T-PWmD8-C6ebNSRszoJY/view?usp=sharing
Thanks,
Pierfranco
Moderator
0
Hi Pier,
I've sent you a PM.
James
