IPv6 settings for 3rd party routers for FTTP/Ultrafast2?
einarnn
Member
Are these documented anywhere? I have IPv4 running, but IPv6 is less forgiving!
Cheers,
Einar
3 REPLIES 3
Bobby
Super User
Hey einarnn,
IPv6 addresses should be assigned automatically similarly to IPv4, but this would vary depending on the router that you have in use. Can you clarify the equipment that you have set up and hopefully someone can give you the answers that you need?
Thanks, Bobby
einarnn
Member
Sorry, lost track of this discussion.
I am connecting a Cisco ISR 1100.
Cheers,
Einar
Leonard0921
Member
tellpopeyes
Cheers,
Einar
How are you measuring the speed, is it via a direct Ethernet cable from the router to your computer?
