Need Help : How to create 1KM Wifi zone ??
samit
Member
Hey friends,
I am Sam, im very much interested to start my owen business .my project is wifi zone 1km long rang .please any one suggest me how i am start my business. how many device i need to create 1 km long range wifi zone? please suggest me .
5 REPLIES 5
Plumly
Grand Master
That is a very difficult question to answer based on the info, you haven't told us the idea of what your doing,
I.e. are you wanting anyone at anypoint to login, are you wanting security,
are you wanting it chargeable,
who will be using it
All this will depend on the equipment,
samit
Member
my main theme is local Internet service provider. basically my user are clients.they  subscribe my wifi connection.my wifi zone coverage distance 1 KM.so now tel me whats type of device need to setup run this business.
Plumly
Grand Master
good luck,
here is a link which might help,
http://hubpages.com/technology/How-to-Build-a-Large-Citywide-WiFi-HotspotZone
i don't think there is 1 Device that could give you a wifi Area of 1k, you would need a few all linked together, unless you use somthing like 3/4G
you will need to have a think about the legal requirements as well, as if the UK Govermnt get there way the ISPs (you) will need to hold all basic data Browsing done by Individuels, so that would fall on you, and you would need to set this up and keep
samit
Member
RichCreedy
Super User
some outdoor access points can be used for this, some can transmit point to point 20KM
