Hi guys,
I am trying to configure port forwarding on my BT Business Hub for my CCTV. In the CCTV manual it says that I need to setup forwarding, Public port 8888 and Private Port 80, but I do not get a such option on BT Hub.
Also when I go toFirewall-->Applications-->Add a user-defined application, then i fill in application name, TCP/UDP ports 80 to 80 and clicked Add to List, and then When i go back to the Firewall settings, and i choose this application to be hosted from the IP of the CCTV, and then click on Save, it gives me a red message "Errors"!!! Why do I get errors?
Any help would be appreciated
What, precisely, does the error message say?
My advice would be to Contact Us
Thank you. But do you know how to setup forwarding, Public port 8888 and Private Port 80, if I do not get a such option on BT Hub?
