Remote access to hub (WAN access)
enveetee
Member
I need to access my router while I am out of the country, is this possible. I have a fixed IP address
1 ACCEPTED SOLUTION
Accepted Solutions
markp
Grand Guru
Hi enveetee
I am afraid the BT routers cannot be accessed remotely.  What you would need to do is access a computer behind the router, then use this computer to make any changes within the router.
Regards
Markp
BT Business Forum Moderator
View solution in original post
6 REPLIES 6
enveetee
Member
I can access my router on my LAN (192.168.1.254) but I need access to it when I am in another country
markp
Grand Guru
Hi enveetee
Regards
Markp
OB
Member
Are there simple steps to follow to remote access a computer connected to a BT router - we have a bt static ip and have tried ftp access using the IP, and BT username and password, with standard and SSH connection - but neither worked.
No doubt it is more complicated, particularly for someone with zero IT knowledge - any pointers appreciated - thanks.
wernstrom
Member
if you're trying to FTP files -to- your own PC from a remote loaction you'll need a few extra steps:
1: set port forwarding on the router to forward port 21 (standard ftp) to the local IP of the pc on your network
2: make sure the firewall on the local pc will accept FTP traffic
3: install an FTP server on the local pc
4: create a user account using the FTP server software.
then
5: using a remote computer connect to your static IP using the credentials created in step 4.
^ all thats a bit simplified as it all depends on your OS version etc etc. but hopefully a starting point 🙂
cheers, Phil.
rog6r
Member
Can anyone let me know how I can set up my Homehub5 so that I can access my DVR remotely using XQ Live on my iPad? I can find my internet ip address using logmein but a fixed ip would be better
PJ16081978
Member
You will need to set up ort fawarding on the Hub. You will need to add a rule
