Server Error
DanMerrill
Member
Not sure if I am posting in right place. sorry
Does anyone use Lotus Notes? When I try to open nsf file which was e-mailed to me, I get the following error:
Server Error: This database cannot be read due to an invalid on disk structure.
Do you have any suggestions how to work around it? What could make the server crashed?
1 ACCEPTED SOLUTION
Accepted Solutions
jimshaffer
Member
This issue can occur if the user has "Always keep a copy" selected for the "Save mail that you sent" option under File > Preferences > User Preferences > Mail. If changing this setting to not keep a copy allows the user to successfully send the message, this would indicate a problem with the Sent folder being corrupt. Running fixup, compact and updall on the mail database should resolve the problem in this case.
Also read info here: https://www.repairtoolbox.com/lotusnotesrepair.html
Regards
View solution in original post
2 REPLIES 2
andyt22
Power User
This isn't really the place to ask about Lotus Notes problems but for what it's worth have a look at http://www-01.ibm.com/support/docview.wss?uid=swg21439899 .
Hope this helps!
Andy
jimshaffer
Member
Regards
