Member
0
Accepted Solution
Static IP addresses and SmartHub 6
Setup pretty simple, smarthub 6 onto BT  infinity wth a block of 5 static IPs.
Have gone through setting up the internal assignemnet of the required public IPs to internal devices, an SBS server and an applcation server.  (Static IP > MultiNAT) Both are on static internal IP outside of DHCP scope and show in the Hub management GUI.
Routing rules are in place and operate on the current public IP.
Despite rebooting the servers they are still not available on the allocated static IPs from the smart hub.
Any ideas or guidance would be appriciated.
BT Employee
0
Re: Static IP addresses and SmartHub 6
Hi BenK.
I have found sometimes the hub has an issue giving out the Static IP to the device that needs the public IP if any other device connected has been manually assigned too.
The way i have found to do it is to manaully configure the Static IP, Subnet Mask and Defailt Gateway of the 5 static range in the TCP/IP settings of the devices that need the public IP address. Give the DNS The Defaut Gateway of the range  too.
You can then setup the port rule to the static IP in the firewall section to the static IP itself.
Hope this helps
Billy
Member
0
As the servers need to be accessed internally as well, we can't apply the external public IPs to them directly.
Super User
0
Hey BenK
That should be possible as you can assign 2 different subnets, it's best calling the technical team on 0800 800 154 and request to be transferred through to second line team who can assist you with the setup.
Thanks, Bobby
Member
0
[ Edited ]
Fixed/Reserved IP address setup :
Advanced -> Home Network -> DHCP Table
Choose device in question -> enter chosen IP address and tick 'always use this IP address', apply.
choose IP address outwith DHCP range (see below) so it's easier to identify, e.g.x.y.z.50 to x.y.z.99
Advanced ->Home Network -> IP Addresses
DHCP Network Range
tick 'Configure Manually'
start =x.y.z.100
end =x.y.z.200
apply
Makes it easier to identify how any device in question was assigned it's IP address.
i.e. IP address of x.y.z.101 = DHCP assigned IP address.
