Static IPs
Mikeyg78
Member
Hi,
I have ordered 5 static IPs from BT and now have them...the problem is i dont have the BT business hub (blew up). I am trying to configure a Netgear DGDN3700 router. The only information i can put into this router is a static IP...which i have put in and it doesnt work. It does however work fine with Get Dynamically from ISP.
BT have just said speak to the manufactures but I am wondering if anyone has a solution on here?
Mike
1 REPLY 1
LogBurner
Member
Looks like you are not the only one:
http://forum1.netgear.com/showthread.php?t=66983
I noticed from this site:
http://www.pcadvisor.co.uk/reviews/network-wifi/3301843/netgear-n600-dgnd3700-review/
"DGND3700V2, this modem / router does not support IPoA protocol, so if your connection is ADSL with static IP probably will not be helpful because most ISPs use this protocol."
Also from
http://www.broadbandbuyer.co.uk/Shop/Reviews.asp?ProductID=10546
"Also had issues adding my ISP static IP and DNS servers.
Got them to work in the end by downloading firmware and flashing."
I have used netgear with a fixed IP and that was OK as I used DHCP but always assigned the same IP.
Good luck
