Power User
0
What is Azure Windows 10 Virtual Machine?
Azure Winsows 10 Virtual Machine (VM) is one of several types of on-demand, scalable computing resources that Azure offers. Typically, you choose a VM when you need more control over the computing environment than the other choices offer. This article gives you information about what you should consider before you create a VM, how you create it, and how you manage it.
An Azure VM gives you the flexibility of virtualization without having to buy and maintain the physical hardware that runs it. However, you still need to maintain the VM by performing tasks, such as configuring, patching, and installing the software that runs on it.
Azure virtual machines can be used in various ways. Some examples are:
Development and test – Azure VMs offer a quick and easy way to create a computer with specific configurations required to code and test an application.
Applications in the cloud – Because demand for your application can fluctuate, it might make economic sense to run it on a VM in Azure. You pay for extra VMs when you need them and shut them down when you don’t.
Extended datacenter – Virtual machines in an Azure virtual network can easily be connected to your organization’s network.
The number of VMs that your application uses can scale up and out to whatever is required to meet your needs.
There are always a multitude of design considerations when you build out an application infrastructure in Azure. These aspects of a VM are important to think about before you start:
The names of your application resources
The location where the resources are stored
The size of the VM
The maximum number of VMs that can be created
The operating system that the VM runs
The configuration of the VM after it starts
The related resources that the VM needs
VM size
The size of the VM that you use is determined by the workload that you want to run. The size that you choose then determines factors such as processing power, memory, and storage capacity. Azure offers a wide variety of sizes to support many types of uses.
Azure charges an hourly price based on the VM’s size and operating system. For partial hours, Azure charges only for the minutes used. Storage is priced and charged separately.
I hope this information will be helpful!
Mark Wilson
