Member
0
professional OLM to PST Converter software
If you are facing any problem with Mac Outlook OLM file Accessing, then use Outlook stores user information in form of PST files and mac Outlook stores user information in form of OLM file format.Sometime it becomes tough to migrate from mac Outlook to windows Outlook without using professional OLM to PST Converter software which can easily convert OLM file to PST format with all email components, such as Inbox, Contacts, Calendars, Tasks, and Notes etc.
Power User
0
Re: professional OLM to PST Converter software
Manually  OLM File to PST Format Steps :-
Step 1: Setup an IMAP account using Gmail account.
Step 2: Add IMAP mail account to Outlook for Mac.
Step 3: Create a Label in Gmail.
Step 4: Move or transferred emails from Mac Outlook to IMAP mailbox.
Hope this helps you.
Member
0
So many utilities available for OLM file to Outlook PST file migration, which can find out in Google search. I would also like to suggest such a Softaken OLM to PST Migration Software. OLM to PST migration uitlity changes mailbox items in OLM into Outlook PST format. This app shows all the flexible emails in preview items before saving. In preview items, you can check your select emails and exactness of adaptable emails.
Softaken for Mac Outlook to Windows Outlook migration is a comprehensive tool that migrates OLM files into PST files or saves the data. This is the best alternative to the free OLM to PST converter. The software supports all the versions of Outlook, and Mac Outlook including the latest versions.
Member
0
As per my experience, I find Pcvita Mac OLM file converter the best utility out there. It provides multiple unique features and helped me convert data from my Mac Outlook account to PST that could be imported to MS Outlook for Windows. I strongly recommend using this software.
If you are a Windows OS user, you can try their OLM file to PST converter tool that works with all Win versions.
Member
0
If you are still looking for a converter tool that allows users to migrate OLM file to PST file format. MailsDaddy OLM to PST converter is the most preferable solution to move data from MAC Outlook to Windows Outlook. It has several useful features and conversion that helps the user to import OLM data into PST, O365, EML, MBOX, Live Exchange & various others.
Notable features: Preview, Bulk conversion, Maintain folders, Save single email, Multiple export format, filter email migration etc.
Power User
0
Follow the steps below to convert OLM to PST manually
Open Gmail account then click on Gear icon on the right-hand side of Gmail account.
After that click on the Settings button.
On the Settings tab, you need to click on Forwarding and POP/IMAP tab.
Then check the IMAP Access status. If the status is disabled then enable it.
Once your IMAP account is successfully created, then you need to set up your Outlook for Mac with it. To do this, follow the steps given below:
First, open Outlook for Mac, then click on Menu ->Tools -> Accounts.
After that, click on Email. Here, enter an email address, password and other information which is asked. Then click on Add Account.
Once the above process complete then check the IMAP mail account.
After that, you need to create Gmail label, In order to perform synchronization between Outlook for Mac and IMAP account. To do this, follow the steps given below:
First, open your Gmail account. Then click on Gear icon on the right-hand side of Gmail account. Then, click on the Settings button.
Then on the Settings tab, click Labels and here, now click on Create New Label. And check Show in IMAP box is checked.
After this, go to your Mac Outlook and click on Send/Receive.
Now will move emails and other mailbox data from OLM file to the IMAP mailbox folder. To do this, follow the steps given below:
Open Outlook for Mac, the right click on mailbox item which you want to transfer to Outlook for Windows.
Then select Move -> Copy to Folder.
After that type the name of your IMAP folder and click on Copy.
Then click on Send/Receive or refresh the folder on Gmail to update the mailbox. You need to do this when the above process completed.
Now your all the copied mailbox data have been synchronized to the IMAP mailbox folder.
After completion of above steps, now you will need to move all the emails or other mailbox data from the IMAP mailbox folder to Windows Outlook. For this, you will need to set up the very same IMAP mail account to the Windows Outlook. Then drag your IMAP mailbox folder data to your Windows Outlook Inbox Folder.
I hope this manual method will be helpful!
Mark Wilson
Member
0
Convert Mac Outlook OLM to Outlook PST file format install an effective tool Convert OLM to PST on Mac Tool. This software easy to converts whole OLM file components such as Export all your Outlook Mac emails, mails, attachments, contacts, calendars, notes, etc. This tool easy to use secure and safe. MailVita OLM to PST Converter for Mac more compatible with Mac. It supports all versions of MS Outlook and Mac versions.
Power User
0
OLM to PST Conversion Software offers you direct migration of OLM files to PST file format so that users can smartly switch from Mac Outlook to Windows Outlook. In a matter of clicks, Mac Outlook mailboxes to Windows Outlook PST file is exported by the tool. It comes with a self-explanatory interface hence even beginners can’t face any issues in handling it. All OLM data items like emails, attachments, contacts, notes, calendars, tasks, journals, etc. are exported safely into PST file format.
More Info:- OLM To PST Converter Software
Member
0
The OLM to PST Converter Pro has been developed as a professional OLM to PST file conversion and migration software, allowing you to convert your data from MS Outlook for Mac to MS Outlook for Windows with no need for any technical expertise or any previous experience.
