when ordering a new Business Infinity what do i get?
Flaggers
Member
I understand that the openreach modems are being retired in March, Im planning on ordering a few Infinity connections before then.
What equipment would i expect to get if I ordered broadband now or in Feb 2016? i.e a openreach modem + hub 3 or perhaps a BT Hub5.
I did hear some suggestion that BT only provide the openreach modem and the customer is responsible for everything else...
1 ACCEPTED SOLUTION
Accepted Solutions
markp
Grand Guru
Hi Flaggers,
with any new fibre broadband orders you will get a Business Hub 5, which has an in built VDSL modem.  If you want to use your own router you can. If your own router does not have an inbuilt VDSL modem you can pur the Hub 5 into bridge mode to disable the router part and use it as just a modem.
Mark
View solution in original post
1 REPLY 1
markp
Grand Guru
Hi Flaggers,
Mark
