Super User
0
Free methods to Convert MBOX To PST
If users want Free methods to Convert MBOX To PST files, then I suggest you use the best software that name is eSoftTools MBOX Converter. It can fastly convert MBOX to PST or other file formats such as MSG, EML, EMLX, HTML, NSF, office365, Yahoo, and Gmail. The software can also give a Live preview option to show all emails and mbox folders before starting the conversion process. Users can also try its free trial pack to convert 25 items from MBOX to outlook pst files formats.
Get more info- Free methods to Convert MBOX To PST
Power User
0
Re: Free methods to Convert MBOX To PST
If you are looking for a reliable and best MBOX to PST converter Tool then, there were lots of third-party Tool available on the web, but choosing the right one is always a typical task for users. Here I suggest one of the best MBOX to PST converter tool which is the MBOX to PST Converter for Mac that provides single as well as multiple MBOX file conversion with any technical glitches. I highly recommend this tool because it supports 20 email clients for MBOX file format like Apple Mail, Thunderbird, Eudora, Sea monkey, Opera Mail, etc. The easily runs on Mac 10.10, 10.11, 10.12, 10.13, 10.14. This software supports all MS Outlook versions like:- 2019, 2016, 2013, 2010, 2007. Download the free demo versions of the software.
Member
0
If you need to convert MBOX to Outlook PST there are two solutions for this One being manual way & the other is a third-party solution. The manual techniques consume a lot of time & the process is also very cumbersome.
So, I would suggest you go for a third-party solution. I have tried MBOX to PST Conversion Tool. This is an efficient software to easily migrate MBOX files to PST file format.
This Application Supports MS Outlook 2003, 2007, 2010, 2013, 2016, 2019. It also supports all Mac OS & Windows versions. You can also try the free trial version, With the help of this trial version, you can move the first few items per folder.
Member
0
If user wants to convert MBOX file in PST format, then users can convert this MBOX file in PST format without losing information. MBOX has many email clients and all are supported by this tool. Entire version of Windows OS is supported by this tool. The tool can migrate MBOX file in different formats like- EML, MSG, RTF, PDF, HTML, Office 365 and more.
To get more about tool, visit:  datarepairtools
Member
0
Download Cigati MBOX Converter Tool is a professional software to convert MBOX email files of more than 20 email clients into different file formats. It can save your MBOX files into PDF, JSON, PST, EML, EMLX, DOC, DOCX, etc.
Super User
0
If you need to convert MBOX files to Outlook PST files quickly and safely, you can use the Softaken MBOX to Outlook Converter software, that can convert several emails from an MBOX file to a PST file without limiting the file size. Refer:- https://www.softakensoftware.com/blog/free-methods-to-export-mbox-file-to-pst-file-format.html
Power User
0
[ Edited ]
There are several methods available on the internet to convert MBOX files to PST. These manual methods need technical expertise to perform the MBOX to PST conversion process.
For converting MBOX file to PST you need to perform three steps
Step 1 - Save MBOX emails as EML files.
Step 2 - Drag and drop the EML files to Outlook
Step 3 - Export emails to PST files.
The manual method takes a lot of time & Only technical experts with experience can safely perform the whole process.
So, In this situation, you can choose MBOX To PST professional tool - Stellar Converter for MBOX that can easily convert MBOX files to PST.
This MBOX to PST Converter supports top MBOX based email clients Thunderbird, Entourage, Spicebird, Pocomail, AppleMail, Eudora, Mulberry, SeaMonkey etc. With the help of Stellar Converter for MBOX, you can perform quick and risk-Free MBOX to PST Conversion without making any changes to the original MBOX file. After the conversion process is done, you can easily import the PST file to MS Outlook 2016, 2013, 2010, 2007, 2003 with the import/export wizard. The simple and easy to use UI makes it very handy for Non Technical users.
For more information, you can check out Stellar Converter for MBOX official page.
Member
0
yes, you can easily convert all files using the DRS MBOX File converter tool.
Power User
0
If you need to convert an MBOX file to an Outlook PST file, I recommend using the third-party software MBOX to PST Converter Tool.
Manual Methods are lengthy to use and take a long time to finish. Additionally, email items and formatting are successfully preserved during the MBOX to Outlook PST conversion process. This application is easy to use even for non-technical users, and it can convert a large number of MBOX files in only a few clicks.
Entourage, Eudora, Apple Mail, Mac Mail, Thunderbird Mail, and other MBOX-based email clients are also supported. With this application, exporting an MBOX file to PST format is a simple procedure with only a few steps.
Member
0
The GainTools MBOX to PST Converter Free Tool is the greatest reliable and effective software that allows users to convert single or various MBOX files to Outlook. By using these applications easily convert all MBOX files into PST files format without any technical knowledge. Users can use the tool on all MS Outlook and perform the error-free conversion from MBOX to Outlook PST format. The software works smoothly with all the versions of Microsoft Outlook 2016, 2013, 2010, 2007, and 2003, etc.
