Member
0
How to open an MBOX file in outlook and Gmail?
Are you searching for the same – “How To Open MBOX File In outlook and Gmail?” Then you landed on the right place, as in this technical guide we are going to discuss the essential procedures by which you will be able to open your MBOX files in Gmail as well as in outlook email client.
We know that opening an MBOX file without any email client was difficult but not now, today we easily open an MBOX file without any email client with the shoviv MBOX viewer tool which is free of cost available.
Read more: https://www.shoviv.com/blog/how-to-open-mbox-files-import-into-gmail/
Power User
0
Re: How to open an MBOX file in outlook and Gmail?
Open the Mbox file in OutlookPermalink
1. Install Thunderbird on your Windows ComputerPermalink
Download Thunderbird from https://www.thunderbird.net, then install it on your computer.
Note: The following operations are based on Thunderbird version 68.
2. Mail Account SetupPermalink
You will need to create a Thunderbird account so that the mbox file can be imported, although this doesn’t need to be a real email account. You can create a fake account just for the conversion process:
On the first launch, Thunderbird will ask you to set up an Email account. You can simply click Cancel to close the dialog.
Click the Newsgroups link in the Thunderbird > Accounts section.
Enter a fake name and Email address in the dialog that pops up, then click Next.create a thunderbird account
Enter a fake Newsgroup Server, e.g. new.example.net, then click Next.
Click Next and finish the wizard.
After the account has been set up, you will see there is a Local Folders structure on the left panel in Thunderbird.
3. Open MBox file in ThunderbirdPermalink
Right click Local Folders, select Settings, click the Browse… button beside the Message Storage > Local directory text field. Change the folder to the directory where the mbox file resides.
Restart thunderbird, and you should see that all messages in the mbox file are now in your Local Folders list.
I hope these steps will be helpful!
Mark Wilson
Super User
0
Yes, you can convert a MBOX file to Outlook PST file format using a MBOX to PST converter tool, but your file can be converted using any tool available on the market. As a result, I recommend using the Softaken MBOX to Outlook converter app. Input the MBOX format. PST is a file format for Outlook.
Member
0
Download the best and safe CubexSoft MBOX to Gmail Converter Tool on any Windows machine and follow the easy benefits to perform the solution of how to export MBOX file into Gmail application. The software build-up so many features and benefits that include batch facility, save all MBOX emails to single Gmail account option, save every MBOX file to separate Gmail account, save report facility, and many more. So that is why many professional experts have always suggested the MBOX to Gmail converter.
Read more: https://www.cubexsoft.com/mbox-to-gmail/
Super User
0
You can effortlessly import mbox to Gmail without Thunderbird with the help of the eSoftTools MBOX Converter. This software in 3 and 4 Step to convert mbox file to PST file. This tool is User-friendly software that easily works by any user with basic experience of IT. The user can take the help of the MBOX Converter for a system for safe and reliable migration. This tool supports all MS Outlook versions like 2019, 2016, 2013, 2010, 2007. It also supports all Windows OS versions.
Read More:- Import mbox to Gmail without Thunderbird
Import MBOX to Gmail Without Thunderbird
Member
0
Want to know how to open an MBOX file in Outlook and Gmail? then you can use the most advanced utility Cigati MBOX Converter Tool to Migrate MBOX files to Outlook, Gmail, Thunderbird, AOL, IMAP, etc. email clients.
