Member
0
IMAP settings for btconnect.com email addresses
Hello,
Can someone tell me if it is possible to setup btconnect.com email addresses up using IMAP and what the settings are? Currently I can only get it working via POP3?
Kind regards
Trevor
BT Employee
0
Re: IMAP settings for btconnect.com email addresses
Hi Trevor
Hope you are well! We would only support the btconnect emails to work via POP3, and not IMAP. My apologies about that - we do have an Office 365 Business Essentials service that lets you use Exchange accounts, but you would only be able to utilise that with a domain email address.
Regards
Ryan
Member
0
Power User
0
@Trevstonbury
Kind regards
Trevor
Yes that is all you get.  you can check it by going to your account at this link:
<https://login.microsoftonline.com>
Enter your full eMail address like: trevor@btconnect.com and password
then under options/Settings you'll see something like this:
POP Setting:
Server name: outlook.office365.com
Port: 995
Encryption method: TLS
IMAP setting:
Access disabled
Server name: smtp.office365.com
Port: 587
Encryption method: STARTTLS
Good luck.
