Member
0
The application was not able to start correctly
I try to open Microsoft Outlook 2016 on my Dell Vostro 14 3000 Business Laptop and at every attempt it shows up that application was not able to start correctly. Somebody please suggest a fix.
BT Employee
Re: The application was not able to start correctly
Hi Phisl033
Very sorry to hear you are having issues with Microsoft Outlook - If the software won't open at all, it is most likely an issue with the program itself. You may be able to resolve that via a repair/reinstall. As that is not a BT service it is not something we strictly support but you can find more info on how to do that here.
Hope this helps!
Regards
Ryan
Member
0
  1. Try to disable Protected Mode.
  2. Close Outlook.
  3. Navigate to “C:\Users\USERNAME\AppData\Local\Microsoft\Outlook“
  4. Delete and clear all files located in the “Outlook” folder so that it is empty.
  5. Open Outlook, and it should re-create and update its data source and function correctly.
If you still experience the problem visit this thread: https://www.outlookrecoverykit.com/
