Member
0
Accepted Solution
resting users email passwords office 360 with BT
hi,
I have office 360 with BT and have up to 10 email addresses/users. We use outlook and i am trying to transfer to a new PC.
Two users have forgotten their passwords and when i try to reset them via the webmail page it says it is not set up.
I logged into BT business account as administrator on the BT website, but i can't see/change their passwords or find setting to enable them to reset the passwords themselves.
the only options i have is to deactivate their accounts.
If i back up their outlook files on current computer, then deactivate thier accounts and set them up again with the same email addresses would that work? on the basis that i can then use the backed up outlook files on the new pc.  Or if not where is the setting to enable password reset?
thanks in advance
BT Employee
0
Re: resting users email passwords office 360 with BT
Hi richwell
Sorry for the delayed reply. There is a bit of a known issue just now with resetting passwords for some accounts - so this could be what is at fault here. That should be sorted ASAP - but depending on your account the issue could be completely unrelated. I would recommend getting in touch with our livechat team here - they can help you get those resets in place after validating the account without you needing to deactivate and reactivate anything.
Regards
Ryan
Member
0
Hi, thanks for reply. Yes live chat sorted it out for me. 👍
