Member
0
Accepted Solution
Problems with btconnect e-mail with iPhone
Hi - can anybody help with an ongoing problem using my e-mail on my new iPhone.
On my PC I am using Outlook Express and can happily send and receive e-mails. Setting up the iPone to send and receive e-mails has been very difficult despite diligently replicating all account settings.
Finally I can receive e-mails but still cannot send any - receiving the error message "The connection to the outgoing server "smtp.btconnect.com" failed". All settings are exactly replicated as per Outlook express."
Therefore if using iPhone to send e-mail via btconnect.com address do I need different SMTP address or port settings.
Any help appreciated!
Super User
Re: Problems with btconnect e-mail with iPhone
smtp settings are correct but O2 uses a different smtp gateway. Check with O2 for the correct relay settings.
- mobile operators force cellular phone users to use a common gateway via which all emails are relayed across. chances are that this will need to be entered here rather than the btconnect smtp address.
Member
[ Edited ]
Thanks - now all sorted.
Have stumbled across this buried deep in the Apple website and this will help anyone else who has a similiar problem
Apple
Cheers
Member
0
well i think ive given aup now !
just bought an ipone and cant get btconnect email working on it for love nor money !
have looked at the website attached for all the details, input those but its not working - im not very technical but the only one that would accept the setup on my phone was exchange, not pop or imp  i think was the other one !!
so any ideas from anyone as im about to throw it through the bloody window !!
KB
Member
Have you tried ...............
Incoming Mail Server: mail.btconnect.com
Outgoing Mail Server: smtp.o2.co.uk
Member
0
I am unable to connect my new ipod so I can send and receive email from my BT account - what exaclty does it need in the Imcoming Mail Server Box and the Outgoing Mail Server Box?
Power User
As Roger says in the post above yours, have you tried the following:
Apple ate my signature!
Member
0
I hope this helps someone.
After quite a bit of trial and error, I finally managed to configure my iPhone with my btconnect email, and did it by using the POP server option.
I input the following info:
Incoming mail server:
host name: pop.btconnect.com
user name: <username>@btconnect.com
password: <btconnect password>
Outgoing mail server:
host name: smtp.o2.co.uk
user name: <o2username as provided by o2 via iPhone message>
password: <o2 password as provided by o2 via iPhone message>
This gives me my btconnect inbox, but not sent items and it does not sync the contacts unfortunately...
Guru
You will never manage to sync the sent items and contacts using a POP3 connection.
If you have an Organise and Share account, you can do it using the Exchange server.
See this post for how to set it up
http://btb.lithium.com/btb/board/message?board.id=EmailBoard&message.id=298
Guru
[ Edited ]
Note, this guide assumes the WiFi/GPRS/3G has been configured correctly on the iPhone.
Edit an existing POP3 account on iPhone:
Details are accessed by EU clicking on:
Settings on the iPhone springboard (aka desktop, home screen), then
Mail, Contacts, Calendars then
Select the BTconnect account on the list displayed (if no accounts exist, see bottom section to add).
POP Account information:
Address: customerusername@btconnect.com
Description: (e.g.) POP3 BTconnect mail
Host name: pop3.btconnect.com
Username: customerusername (omit '@btconnect.com')
Password: customerpassword
Outgoing Mail server: smtp.btconnect.com (tap this option for the info below)
Primary server: smtp.btconnect.com (no other SMTP servers switched on)
Other SMTP servers: <none>
NOTE: If connection to the primary SMTP is down or incorrect, the iPhone can & will use any SMTP servers it has listed as 'Other SMTP servers' on this screen, if they are switched to ON. For duration of testing all 'Other SMTP servers' should be switched OFF.
Click on Primary Server
(e.g. smtp.btconnect.com)
Host Name: smtp.btconnect.com
Username: customerusername@btconnect.com (include '@btconnect.com')
Use SSL: Off
Authentication: Password
Server port: 25 (iPhone may try & default this to 587 if an aborted IMAP setup has taken place).
NOTE: SMTP authentication MUST be enabled to allow customer to send email on the move. A solution whereby SMTP Authentication is disabled will NOT work when EU is away from their BT Business broadband.
Advanced:
Deleted messages: Remove after one week
Incoming settings:
Use SSL: Off
Delete from server: Never
Server Port: 110
To ADD a new account to the iPhone:
Click on Settings on the iPhone springboard (aka desktop, home screen)
Select Mail, Contacts, Calendars
Select Add account... on the list displayed.
Choose Other...
Enter your account information:
Click Save, iPhone will move to next screen...
Select POP & move down to:
Then
Then click Save
The iPhone will then try & verify the POP settings via SSL & will fail. This is normal.
iPhone will then report Cannot connect using SSL, Do you want to try setting up the account without SSL? Click YES
iPhone will then try & reverify POP details, this may take up to 3mins!
Note: Even if the information provided is correct the iPhone may display a message saying the SMTP account verification failed, authentication not supported. Ignore this & click Save. A warning will be displayed: This account may not be able to send or receive email. Are you sure you want to save? Click Save
If successful you will then be back to the Mail, Contacts, Calendars settings screen.
(If the POP3 or SMTP verification failed, check the POP3 & SMTP details again, SMTP password WILL need to be re-entered if SMTP verification failed).
Click Home button (on the front, below the screen)
Launch Mail from springboard, choose BTconnect account if multiple selections are available.
Test by sending/receiving.
(If still not working, iTunes can force email accounts from the iPhones' host PC/Mac, however this is outwith the scope of this guide & should only be performed by persons familiar with this procedure as it can be destructive to data on the iPhone).
Thanks to KateWinsletsHT for this guide,
Message Edited by spank on 12-08-2009 01:38 PM
Message Edited by spank on 12-08-2009 02:11 PM
