Android Virtual Device for Huawei Mobile Services
AlvaradoWright
Member
I want to apply HMS to my app. However, buying an actual Huawei phone is not on my shortlist. Does Huawei provide an Android Virtual Device for that purpose? If not, how to test if my implementation of HMS actually works?
Official Website
9 REPLIES 9
Lenard
Member
Official Website
Yes, Huawei do provide an Android Virtual Device called Cloud Debugging of AppGallery Connect to test your app for Huawei Devices.
Cloud Debugging tests your app using mainstream Huawei devices provided by Huawei. You can run your app on the latest and most popular Huawei devices to test app functions. Besides, you can debug apps on two real devices at the same time using one HUAWEI ID. Assume that you have applied for a device successfully.
Peter69
Member
@AlvaradoWright wrote: prepaidgiftbalance
Official Website
FloresF
Member
Create new or run existing Android emulator via Android Studio or ADB. Install HMS Core APK downloaded from Go to Settings -> Apps & Notifications. Make sure that HMS Core has required permissions like SMS for SMS retrieving or push notifications.
Eleanor69
Member
An Android Virtual Device (AVD) is a configuration that defines the characteristics of an Android phone, tablet, Wear OS, Android TV, or Automotive OS device that you want to simulate in the Android Emulator. The Device Manager is an interface you can launch from Android Studio that helps you create and manage AVDs.
MyHTSpace
Leon69
Member
I appreciate the information and advice you have shared. I will try to figure it out for more.
HISD Connect Login
Leon69
Member
@AlvaradoWright wrote: My Waffle House
Official Website
Android Emulator allows you to run emulations of Android devices on Windows, macOS or Linux machines. The Android Emulator runs the Android operating system in a virtual machine called an Android Virtual Device (AVD). The AVD contains the full Android software stack, and it runs as if it were on a physical device.
Leon69
Member
@AlvaradoWright wrote: Novitasphere Portal
Official Website
miamas
Member
I am grateful for the information and the suggestions that you have provided. I will make an effort to understand it better for more.
KDealer
miamas
Member
Same I have exactly the same doubt
check here
