I am doing android-azure mobile app offline sync. and currently use this code to pull table
table.pull(query).get();however with this the max top is always 50 which causes many calls. McDVOICE
now to set top i read, you have to do ,
QueryOperations().fields().top()but if i do not have any conditions then query variable will be null, and hence I am not sure how i set "top" parameter.
I am very much new in android. so if question is not good, feel free to edit. 🙂
This guide shows you how to perform common scenarios using the .NET client library for Azure Mobile Apps. Use the .NET client library in Windows (WPF, UWP) or Xamarin (Native or Forms) applications.
@crystal458 wrote:check out this : https://stackoverflow.com/questions/44328937/increase-max-count-azure-mobile-services-android/EmployeeConnection.net Insite
I was looking for the same. Thank you for sharing the link, I will try to figure it out for more.
Choosing the right page size is a balance between memory usage while the request is happening, bandwidth usage and delay in receiving the data completely. The default (50 records) is suitable for all devices. If you exclusively operate on larger memory devices, increase up to 500. We have found that increasing the page size beyond 500 records results in unacceptable delays and large memory issues.
MyBalanceNow
Throughout this article, the term "client" refers to any entity that accesses Service Bus. A client can take the role of a sender or a receiver. The term "sender" is used for a Service Bus queue client or a topic client that sends messages to a Service Bus queue or a topic. The term "receiver" refers to a Service Bus queue client or subscription client that receives messages from a Service Bus queue or a subscription.
This works really well for us, thank you! Pay by Plate Ma
@Isobel69 wrote:
@Cody145 wrote: Five Nights at Freddy'sI am doing android-azure mobile app offline sync. and currently use this code to pull table
According to the Azure offical tutorial How to use the Azure Mobile Apps SDK for Android, it said as below in the subsection Return data in pages.
wow, the information provided is what has been bothering me for the past week. Thanks a lot
Azure Mobile Services is now deprecated, and Microsoft recommends migrating to Azure App Service. However, if you are referring to the maximum number of records returned in a single query, you can use the "$top" query parameter to increase the maximum count. For example, to retrieve 100 records, you can add "$top=100" to your query URL.
Thanks for sharing.
