Member
0
Accepted Solution
An unexpected error prevented access to thefile
Here is my problem:
When opening Outlook .ost files i get this error: An unexpected error prevented access to this file
I have try uninstalling and reinstalling Outlook but still the same. Any others experiencing this?
Member
0
Re: An unexpected error prevented access to thefile
The OST files might be marked as read-only, and if so you probably want to uncheck that setting. Also read info here https://www.ostrepairtoolbox.com/
Member
0
Thank you! i had the same problem!
