Member
0
Get Solution for Epson Printer in an Error State
Sometimes the solution of the Epson printer in error state can be a difficult problem for the user. In this blog, share simple steps to get the solution for the printer in the Epson error state.
Power User
0
Re: Get Solution for Epson Printer in an Error State
Fix 1: Fix hardware issues
Check 1: Check the power cord of your Epson printer. Ensure it is properly connected to the board and the switch is turned on.
Check 2: Check if the USB cable is connected to the PC. If there is any issue with the cable, then try a different cable.
Check 3: If it is connected wirelessly then, make sure it is connected to the network.
Check 4: Try printing on blank paper.
Fix 2: Turn off and restart your printer
Step 1: Stop all the printing jobs, and turn off your printer
Step 2: Cancel all the printing commands in the queue
Step 3: Restart the PC and you’ll find that the issue is fix.
I hope both these methods will be helpful!
Mark Wilson
