Member
0
Disconnecting someone off my BT landline.
A family member is using landline phone constantly incoming and outgoing.
Is there a way to use computer or code on another handset to disconnect them without knowing it was me.
I dont want to block incoming or outgoing calls and simply asking them makes no difference.
Just want a way to disconnect the active call. Picking up other handset and pressing hangup obviously does nothing since it is in use on the other handset.
Is there something I can do to get the call to drop other than pulling out the master cable.
As said is there an engineer code to dial or perhaps something from a PC...
