Member
0
How to change system ram?
I have 2 gb ram and would like incress it due some reasons. How can I do this.
BT Employee
0
Re: How to change system ram?
Hi Phillcalls
Hope you are well. Are you just looking to get more RAM on your PC?
Regards
Ryan
Member
0
Yes I am still looking for it. Any suggestion!
BT Employee
0
Hi Philcalls
I would recommend going to a computer store like Curry's or PC World - they would be the best ones to speak to about upgrading your RAM and could have conversations about what is best to suit your needs etc Smiley Happy
Regards
Ryan
