Member
0
Secondary Socket
I am having a new business line installed tomorrow AM which will be the support line that connects to the lift control room should someone be stuck in the lift.
I have had a contractor pre run a CAT 6 cable that goes from the location of the master socket to the control room. Just to double check, will a MK BS6312 be ok to use for a secondary socket? Just looking for some confirmation otherwise I will order a secondary socket ready.
Thank you
Member
0
Re: Secondary Socket
***Mistake (MK BS6312) - MK Master Socket*
Member
0
Thank you
All MK telephone Master and Secondary outlets are either independently.
Member
0
@Annie335 wrote:
I have had a contractor pre run a CAT 6 cable that goes from the location of the master socket to the control room. Just to double check, will a MK BS6312 be ok to use for a secondary socket? Just looking for some confirmation otherwise I will order a secondary socket ready. ifacetimeapp
Thank you
