Hi, I have recently taken delivey of a BT Falcon Mk2 IP Phone TB-30, I don't plan to use it on the BT Hosted VoIP service I want to connect it to my own VoIP Server. Hence I need to configure it manually.
The simple guide that came with it doesn't mention, the default password to get in to the "Admin" menu. I found a full user guide on the web here .. http://btbusiness.custhelp.com/euf/assets/pdf/BT%20Falcon%20Mk2%20IP%20Phone%20User%20Guide.pdf
However in there it says the default password is "0000" I've tried this and all I get is "Input Error !!!".
The Phone's firmware is currently v1.70.4 is there a later version if so where can I get a copy of it from?
Kind Regards
Plasma
Solved! Go to Solution.
Never mind I've found the answer! The phone is made by Thompson (same people who make the BT Home hubs).
Thompson Websiite - http://www.technicolorbroadbandpartner.com/telephony-solutions/products/product-detail.php?id=216
The usefully provide an Admin Guide which states on page 54 ..
Step 2 – Connect to the IP Phone web server
1) Start a web browser session
2) Input the phone‟s IP address into the address field. For example:
i. http://10.1.97.6 for user mode.
ii. http://10.1.97.6/admin.html for admin mode.
3) Enter the username (by default: administrator)
4) Enter the password (by default: 784518)
5) Once the process is completed, you can change the settings values to your convenience.
Hope that helps others with the same problem.
Cheers
Plasma
Cheers
Plasma
I had been looking for AGES for the BT Falcon Technicolour / Thomson TB30 default admin password for such a long time. Considering the details above did not work for me. Plus, a factory reset option was not an option either, so I monitored the phone traffic upon bootup.
I have now found the correct Admin login details:
Logging in to the phone directly:
Password: 159753 (not 784518 as suggested)
Logging in to the http version on local network:
Username: admin (not administrator as suggested)
I have also found that the 'user' username is indeed: user
No password requried there.
Finally there is the Telnet ID: user
And Telnet Password: 789234
I hope this info saves people a lot of time.
Best wishes
Jimmy
(Phone hacker)
Just one thing to add to this excellent post...
The telnet userid is admin, not user. (user doesnt work) The password for admin is : 789234
The rest of Jimmy's post is spot on, and has indeed saved me a lot of time...
Robert
These same credentials worked for me. However, i flashed all my Thompson TB30 to SIP since i wanted to use them on Asterisk server. All working great!!
Strong phones and feels like Alcatel
This is a BT Falcon TB-30 VOIP phone as used with systems like BT Hosted VOIP Telephony talktowendys.
