ISDN2e - No Connection
dave_edinburgh
Member
Hi folks
I'm trying at setting up phone systems at work and can't get it working.
What I have:
ISDN2e from BT.
Seimens Gigaset DX800A all-in-one phone system (1 x base, 6 x handsets)
What I have done:
I connect 1 cable (RJ14 perhaps) from BT NTE8 ISDN2e box to base station.
Base station recognises ISDN line and starts connection wizard. I get a solid green light on ISDN2e box.
Base station doesn't recognise MSN number - I manually set this and end wizard.
However, when I try and dial, I get no connection.
I've tried various combinations for the MSN number:
44131 XXX XXXX
0131 XXX XXXX
131 XXX XXXX
XXX XXXX
XX XXXX
No success. BT has tested the line and reports no faults.
Any help/ideas would be appreciated!
Dave
9 REPLIES 9
Davel
Super User
On most telephone systems when programming MSNs you don't need the area code. In your area which is a Director area I don't know if you would need the exchange code as well so just try the last 4 digits.
dave_edinburgh
Member
Hi Davel
Thanks for the suggestion - I've tried this, but still no luck. Any more ideas?
Davel
Super User
Normally if you don't programme a MSN it willl automatically ring the main handset or group. What do you get if you ring the number?
dave_edinburgh
Member
Every time I get call failed!
Thanks!
celavey
Power User
I agree as I don't usually use area codes. Whenever I dial a number, it will automatically recognize where I am calling.
ShuggyM
Member
Hi Dave,
Did you ever get a resolve for this issue we have the DX800a, BT isdn 2e and get the same issue.
Hugh
john999
Member
hi davel........
topman
Member
Hi,
did you manage to get your system working in the end? If so what did you need to do?
dave_edinburgh
Member
Yes. We had to get the line changed from "point to point" to "point to multi point"
Once we knew this, it was simple for bt to do.
Dave
