LotusNotes program
hugogg
Member
Hi,
LotusNotes program has worked fine for me, until when the error appeared when trying to open .nsf file: "Cannot Allocate Space." What does this message mean? Please help me
1 REPLY 1
bhampton
Member
This error often indicates database corruption. In this case, you may be able to work around the issue by running Fixup, Compact and Updall as follows:
  1. fixup -f (This causes Fixup to check all documents in the database.)
  2. compact -i -c -d -K (ignore errors, copy-style, delete view indexes, set large UNK table)
  3. updall -R
If the method above does not work to repair lotus notes the file, please also try the following: https://recoverytoolbox.com/lotusnotes.html
