Thanks BT for the upgrade last night to 6.15.1. But now the search function doesn't seem to work properly. Any chance somebody could take a look at it?
Cheers
Hi graemewilliams,
I have had a look at your website and the serach function is working for me. What borswer are you using to access the site?
I would suggest trying in a different bowser/computer and if your site is still having problem please do contact the helpdesk.
Regards
Markp
BT Business Forum Moderator
Hello Markp
Thanks for your reply. Yes, I've already noticed it seems to be working again. However, I assure you it wasn't when I made my original post.
Anyway, whatever the problem was, seems to be fixed now. Thanks.
