Member
0
Moving Office and Needing New Lines
Hi All
We are moving in to a new office and need the following
* standard broadband connection
* phone line which allows 2 phones to ring at the same time
* phone line which allows 2 phones to be used at same time to call different numbers
At the moment we have 1 phone and are missing calls when the phone is in use so need a 2nd phone to avoid this situation.
Nothing else too fancy...
What is the best way to do this??
Kel C
BT Employee
0
Re: Moving Office and Needing New Lines
Hi Kelso_SanDiego,
The easiest solution would be to get a Featureline with 1 auxiliary line. So you would have 1 main number but have 2 or more phones connected to the line, and be able to make 2 calls at the same time. If you wanted to make say 3 or 4 calls at the same time you would add more auxiliary lines.
Best to contact our sales team on 0800 800 152 who will be able to best advise you Smiley Happy
Regards
Ryan
