BT Business Smart Hub 3 DHCP IPv6 settings allocation mode off / firmware updates
bakery
Member
Installed hub 3 and set IPv6 settings allocation mode off. 5 subsequent firmware updates have caused hub to revert to default IPv6 settings allocation mode on.
The initial firmware displayed a greyed out backup settings option - the 5 subsequent firmware updates have no backup settings option.
The hub has to be powered off then on every few days to resolve network connectivity problems with wired attached computers.
The BT Business Smart Hub 3 was supplied with a new Hyperfast 2 Enhanced FTTP contract.
Previous FTTP contract was supplied with a BT Business Smart Hub 1 and in use for 4 years without issues.
Since initial installation version - 5 subsequent firmware updates in 5 weeks clearly shows there are significant issues with the hub 3.
r1.8.2-R-834786-PROD-83002
r1.14.0-R-866605-PROD-83002
r1.17.2-R-896023-PROD-83002​
r1.19.1-R-898041-PROD-83002
r1.21.0-R-910349-PROD-83002
Are there any online BT release notes / status for BT Business Smart Hub 3 firmware updates?
4 REPLIES 4
BethM
Administrator
Administrator
Hi bakery
We do not publish the release notes for the BT Business Smart Hub 3 publicly.
^BethM
bakery
Member
Hi BethM
Thank you for reply.
Why do firmware updates cause hub to revert to default IPv6 settings allocation mode on? There seems little point in allowing users to change settings then without notice they are undone by firmware updates.
When will backup settings option be available (as it has been in previous business hubs)?
Is the BT Business Smart Hub 3 a trial status product which some members / admins refer to or fully released stable product? see post below
SamG
Administrator
on ‎19-06-2023 04:34 PM
Hi @kp149 ,
Thanks for your post.
If you've received one of the new Smart Hub 3s then you'll be part of the trial. Don't worry - you're protected by all the usual T&Cs, including the usual guarantees and speed promises.
We respect the requirement for privacy and take notice of your decision to withhold the BT Business Smart Hub 3 release notes. dignity of privacy upheld.
BethM
Administrator
Administrator
Hi bakery
If your settings are being reset with every firmware update, it might be worth our Team team investigating. If you want, please send me a private message with some account details.
The back-up settings option is in the pipeline but no current timeframe for this I can advise.
The BT Business Smart Hub 3 is a fully released and supported product, not just a trial now.
^BethM
