J-in-L
Member
I was told "The number you have dialled has not been recognised".
But this is the number I was given yesterday by the twitter BT Service Status update site
I tweeted them that it didn't work but their robot couldn't understand !!!!
Someone should fix it.
1 ACCEPTED SOLUTION
Accepted Solutions
Fiona
Grand Guru
Hi
The number has now been updated and the issue was replied to on thread - We’ll tweet you with updates on your Broadband fault progress
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
View solution in original post
2 REPLIES 2
Fiona
Grand Guru
Hi J-in-L,
I have asked someone from the Twitter team to look into this, i'll keep you updated.
Kind regards
Fiona
Fiona
Grand Guru
Hi
Kind Regards
Fiona
