2 dedicated lines with cordless phone setup...help needed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
currently have the following set up:
2 separate landline numbers that are used simultaneously and frequently
1 dedicated fax line that is used sparingly, but does have its own fax number.
basically i have 3 separate phone numbers....all could be used at the same time, i e 2 people are talking on the 2 phone lines and i could be receiving a fax.
i have a 2 line cordless phone system that i would want both numbers to ring to and to all the handsets.
Base: Panasonic KX-TG9322T 2-Line DECT 6.0 Cordless Phone, Metallic Black, 2 Handsets
cordless: Panasonic KX-TGA939T Extra Handset for KX-TG93XX Cordless Phones Series
i want to move to ooma, either the telo or hub, however, i am unsure what the setup would look like and whether this is even possible?? and what i need to buy?
i am looking for:
1. which ooma system to buy: hub or telo?
2. the physical setup?
I didn't find the right solution from the internet.
References:
https://www.ooma.com/forums/viewtopic.php=14693
