All requests through the gateway are being blocked by IAC (Internet Access Controls) on the router. Requests appear in the Access Controls log and browsers are re-directed to:
http://gateway.2wire.net/access/site_blocked.html?NODEID=48&APP=IAC
This also happens for clients that are marked in IAC "All Allowed".
Aditionally when typing in the admin password to temporariily allow access, access is still denied.
nslookup on a site returns correct IP's from the gateway and it can be pinged from the internet.
I am looking at the MDC now but don't really know what i'm looking for.
Cheers
Chris
Solved! Go to Solution.
Have you setup the Access Controls at any point?
If you factory reset the router it might remove the access controls from doing this.
Also what verison of the firmware do you have? 5.x.x.x.x or 6.x.x.x?
Thanks for your help, a factory reset and reconfigure removed the problem.
This is running 5.29.117.6
