A couple of questions about a new connection
nigejn
Member
Hi Support
We have just had ADSL activated on our line and I have a few questions regarding the connection.
1.  The phone line is patched directly into our Patch Panel so no RJ11 socket is avaliable, what is the best way so connect  this, Move the Line to a BT ADSL Socket or use a RJ45 Line filter.  We are currently using a Master Line adapter in between the Patch Panel and Filter which I think is causing an issue.
2.  We have 5 fixed IP's and I've having a little trouble configuring the router (Non BT) Which IP is the Gateway address from the email i've received? Network address, Router/Hub Address or something else.
Thank You
Nigel
0 REPLIES 0
