Advanced Package + Zend Optimizer?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello,
My friend bought Advanced hosting package at BT and asked me to help him with his website. Actually he needs a special php+MySQL CMS to be installed onto the server, but there's one issue - this CMS requires ZendOptimizer to be available. I have an experience of building custom PHP engine + ZendOptimizer on FreeBSD servers but as I may understand - CentOS is used on BT hosting and I don't know how to install all this there. Is there a possibility to set up ZendOptimizer somehow?
UPD: first of all I need help to build custom CGI PHP (PHP as a CGI module). To do this, basilly I need the php.ini file with the same settings as at the whole servers. If I run phpinfo() script at BT - I see that the directory for php.ini is /usr/local/lib/php.ini but I cannot copy the ini file from there - it says there's no such file. Can anyone help?
Thanks,
Alex
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi aexb,
can you please provide us with your domain name?
Tracey
BT Forum Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You will not have the level of access required to modify the PHP config files.
This is a shared hosting package and if you were to be allowed that level of access you could break PHP for all the other users.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Tracey,
It is evora-energy.com
I would really appreciate if you could help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Dave,
Not at all - this mostly depends on server configuration. If I will be able to make my own PHP as CGI module - it will use its own php-cgi.ini config file and this will never break PHP for other users.
But I read some server documentation and noticed that compilation is disallowed there. So I need BT technical assistance to install Zend Optimizer for my domain.
Thank you!
