Hi, I hope someone can help as I have experienced this problem for over a week!
I am trying to change the order of new my pages on the navigation bar, but when I attempt to save or publish the alteration, the site simply refreshes back to how it was.
Is anyone else having this problem or who can advise what the issue is? I am definitely not doing anything wrong as I make these changes on a regular basis... I am using EasySiteWizard Pro.
Thank you.
Solved! Go to Solution.
Hi,
I think I might have found your issue (please ensure you perform step 7 below) - if you follow the steps below exactly, the changes should be made.
Adding new pages
Adding a new page can be achieved in a few simple steps, these are:-
1) Within ESW, click on the icon that looks like a page with a plus on, within the menu bar
2) This will bring up the page editor screen. Click on Create Page
3) Follow the instructions.
Please ensure the file name contains no spaces.
4) Select Apply
5) You are then taken to a pictorial view of your current pages, from here click “create new
button”
6) Where it states Label, add in the page name you would like to be displayed
7) Finally, where it says “link to” select “page” and find the page in the dropdown list
RE: menu layout, you can find further information in the advanced features guide (click on above URL)
Lisa
Hi,
I don't know if this is the case, but...........
I just tried this twice and saved the changes using 'menu editor'. It saved my changes but was not visible until I re-published the site.
Peter
Hi,
Adding new pages
4) Select Apply
button”
Lisa
