Another FormMail question
loz25
Member
Hello all,
I know this will probably be a stupid question but:
Ive installed the form mail script and made a contact form.
Is the whole form mail thing free to use? i.e do you have to have a certain BT hosting plan to use it?
Im doing this for work and want to make sure by installing a form we are not going to go over certain BT email limits or hosting limits (if this makes sense)
Also do i need to make sure our hosting package supports php?
Many thanks in advance.
2 REPLIES 2
dave
Guru
It is free, and you can generally use it no problem without going over any limits (unless you are using it to mass mail people).
All the hosting packages support PHP.
loz25
Member
Hi
Thanks very much for answering my question, hopefully it will work now!
