Hi,
I just renewed with BT and opted for 5 static IPs as I have a server and CCTV I would like to access - currently using DDNS.
How do I go about setting up the multiple IPs? I read in aother forum that I need to change my WAN connection to Static IP, under WAN IP SETTING I add the IP address, Subnet mask and default gateway - here I entered the network address under ip address and default gateway the router/Hub address and subnet mask for 5 static IPs 255.255.255.248.
I entered DNS 8.8.8.8 and 8.8.8.4
Authentication 8.2.1x MD5 entered my network login username and pass.
Set to Apply and nothing. I had already disconnected my modem from the line for a few minutes as recommended.
I would appreciate any advice here.
