We have lots of these Huawei £g modems in the company for use with Cisco VPNs
I want a desktop shortcut for The Cisco Client
User will fire this up and will choose from either a LAN/wireless or 3g/GPRS connection
The client will then either fire up the BT access manager and make a connection or go out over the LAN.
I want to know if there are are command line options for startng BT access amanger and connect to a particular profile - Bt 3g/GPRS in particular. BTOMO doesn't seem to take any command line options other than btomo /profilename which just re-registers the profile - it doesnt connect it.
My BT account Manager didnt know.
My BT ICT specialist doesn't know.
If no-one knows about it maybe they couldadvise who to speak to about it.
Solved! Go to Solution.
Hi,
I'm afraid that BT Access Manager cannot take a profile name to connect to as one of it's command line parameters.
I think your best option would be to turn everything round and use BT Access Manager to establish to connection, then start the Cisco VPN Client. You can use the 'Home Page' profile setting to run the Cisco VPN Client after connecting using profile. This is accessed from the 'Home Page' tab on the 'Settings' panel, and would need to be configured for each profile you wanted to connect with.
For the Cisco VPN Client you could use '"C:\Program Files\Cisco Systems\VPN Client\vpngui.exe" -c <connection entry>' as your 'Home Page', where <connection entry> is the name of the Cisco VPN entry you want to connect to.
Hope this helps - Let me know if you need any more information.
Tim
Hi,
Tim
