BT Business VoIP Handsets
martin86
Master User
Hello,
We have just regisered for the BT Business VoIP service. On the back of the router there is the phone line connection which looks like an RJ11. I am told that many phones will work..even normal household handsets? I would need an RJ11 to normal telephone connection adaptor.
Basically I am asking which phones are compatible and where is best to look? We only need something basic.
Many thanks,
2 REPLIES 2
MHC
Guru
Not quite.
I presume you have a 2wire2700/2701.   If so, there was a special adapter supplied with it which splits the RJ11 output into 2 lines - a standard RJ11 to BT (BS6312 431A) wwill not work as you will have one leg of a pair on the ring wire.
Any analogue phone should work with it - I have several different ones running on mine.   The plces such as the online BT shop, Argos, Currys &c.
SeanC
Master User
Hi Martin
If you do not have the 2wire splitter can you please send me a private mail with your broadband number and ill get one sent out to you.
regards
sean
