I regularly ( 5 times in the last week) have to restart my BT hub 3 to restore my internet connection , is this likely to be hub problem ?
ADSL+
Wired
I assume the hub is losing connection , but it isn't showing same behaviour as previous routers where lights would quickly go out , start flashing , then reconnect within 2-3 of minutes after a disconnection .
This morning lost internet at 8.59 , all light blue , router status "connected"
9.08 middle orange light . router status "connecting"
9.09 all lights blue . router status "connected"
9.10 middle orange light , router status "connecting"
9.16 restarted router
9.20 working internet
Same pattern 5 times in the last week ,except 2 occasions where i couldnt access the router and had to power it off and restart
Hi,
Helpdesk.
Dave
Hi Dave ?
Was that an answer ?
Should i call the helpdesk ?
Again
I would say that you need to call the Helpdesk and go through it with them - you may well need a new Hub.
Been there , done that (90mins last weds) , sick of the same questions . No T shirt .
Supposed to email somebody next time the router plays up so they can test the line again , assuming she is at work the next time .
Again
Hi,
Yes it was. You didn't say in your original post that you'd been in contact with them already.
Dave
The HUB3 router is crap will always be crap and should be treated as crap and flushed down the toilet.
Hope this helps.
