Back to a problem I had in March 2010 (page 31 if you want to trawl that far back) basic problem is my Belkin print server has stopped communicating with my BT Hub e.g.. I cant print wirelessly any more. Been through all the settlings and they seem ok but the only way I can get the Belkin print server to communicate with the BT hub is to connect them directly via an Ethernet cable.
When I go to 192.168.1.254/broadband/lan/stats is lists the 3 devices I have - 2 Laptops - Interface 'wireless' and the Belkin print server - Interface 'port1' is this my problem if so how do I change this interface to 'wireless'
Print server was working ok until a couple of weeks ago but the BT hub went down and I had to reboot it and that is when the problem started
any clues?
Is your print server correctly set up in your networking (not the Hub)? This could be an issue with File and Printer sharing?
