Has anyone setup SBS 2011 using BT Infinity and a static IP address to successfully use MS Remote Web Workplace? My problem is that SBS 2011 uses one NIC which must be set up with a private IP address (192.168.x.x) but configuring static IP's using the 2701 router by default wants to assign the public (static) IP address to the NIC. Can this be worked around using port forwarding and if so how is this done? Any help much appreciated.
The simple answer is yes, port forwarding would be necesssary. If you know the port(s) and protocol(s) required, then Contact Us and we can help you set this up in the Business Hub.
We don't, however, provide helpdesk support for SBS.
