I have E170 HSPA USB Stick, and simm in it, but can't get a mobile connection.
Due to various test I'm confident its a problem with the SIM, I think I might have to activate it?
Can someone tell me
a) is there a support number for BT that I can call now 11:35 on a Saturday?
b) if there is an activation procedure for SIM's what it is?
thanks
Solved! Go to Solution.
Hi Silversurfer,
You can can contact BT Mobile to help with this matter 24/7. You can find contact details for the department via this link BT Mobile Contact.
I hope this helps
Regards
Sean
Hi Silversurfer,
I hope this helps
Regards
Sean
